is it somehow possible in R8 or will it be in R9 to attach Section style to a Material? Therefore if I apply material to an object, it will also get specific section style with it?
Or maybe some sort of “Named section styles” so you dont need to click through every single option everytime you want your clipped object look some way?
Perfect option would of course be “named section style” that you can attach to a material. That would be a gamechanger.
Would be much appreciated in architectural technical drafting that you would be able to go direcly from textured model into a technical drawing without a need to define every parameter separately to each object.
Linking section styles to materials isn’t possible yet, but the Rhino BETA covers the “named section styles” part of your request:
Document Section Styles: You can define and name section styles in Document Properties, then assign them to objects, layers, or clipping planes. Editing a style updates everything that uses it. Details: Rhino BETA Feature: Document Section Styles
Workaround for material-driven styles: Set up layers by material, such as a “Concrete” layer with both the concrete material and a concrete section style. Then objects on that layer get both at once.
Hopefully we can get the true material hook-up soon. It is already logged here: RH-78717
