Hello there. For no reason, my materials disappeared while working on my Rhino model. I use vray for rendering. When I look at my library of materials, none of the items have been deleted. They seem as they should be, but they do not appear on my model. I can only see them while rendering. Otherwise its just appears as a single color in all modes except render. I have limited time to complete my project, I cannot reassign all the materials. Is there any solution to fix this?
I am not sure exactly which versions I am using for vray as my program downloads are made by the IT department of my school. I’m using v-ray 5 for 3dsmax, I might have confused it. I’m not sure which vray I’m using for the Rhino 5. Can’t we still find a solution to this problem?
I’m trying to determine if your problem is solvable in a first place. That’s why I need the V-Ray version number. Can you please go to menu bar, then hit `V-Ray->Help->About V-Ray" and post a screenshot of the dialog that pops up here.
Since we have been training online, I cannot install them for higher versions now. When I try to install it myself, I cannot set up v-ray. I am not very good at these issues. Actually this problem happened while I was on zoom meeting. My computer changed its resolution for no reason and all of my textures gone. When I turned it back to old resolution it was still same (no textures) . The same problem occurs with my friends using the upper version rhino and vray. None of us can find a solution.
