Is there a way to list layers in alphabetical order when trying to assign a material by layer?
In “Layers” window, all layers are listed in order, but the material assign by layer window shows all layers out of order.
This was recently fixed in the Rhino 8 WIP… https://mcneel.myjetbrains.com/youtrack/issue/RH-71588 Are you using Rhino 7? I can check if the fix can be added to a v7 service release if so.
yes, I’m using Rhino 7. That will be great if the fix can be added to 7, please.
It looks like this was actually a separate issue so I filed it as https://mcneel.myjetbrains.com/youtrack/issue/RH-72595 and asked that the fix be pushed to a v7 service release as well. Thanks.
RH-72595 is fixed in Rhino 7 Service Release 28 Release Candidate
