Good evening,
Rhino doesn’t match the mapping corectly. It matches the type and size but not the position.
You can clearly see this in the video below.
Good evening,
Hi @Bogdan_Chipara ,
I can’t reproduce this issue, can you post your 3dm? Here’s my test file too.
MatchMapping.3dm (325.4 KB)
have you tried with cylinder mapping ?
Yes, post your file.
240930 _ matchmapping problem.3dm (2.6 MB)
ok, I know how to replicate this.
I believe this has to do with the objects being very, very far away from world origin. Select both objects, move them to around w0 and the match mapping will now work as expected.
@nathanletwory No is not. I can replicate it even when the geometry is right on the world origin.
Please have a look:
Hmm, weird, this morning when I tested it moving to around w0 remedied. Testing it again it no longer does.
I logged this as RH-84052 MatchMapping doesn’t map correct cylindrical mapping
@nathanletwory , it happens with box mapping also.
MatchMapping mathes the previous location of a mapping even if the object with its mapping has been moved.
