Hello Everyone, I have just started learning Rhino. I have a problem, I have multiple 13 meshes from a scan of a skull, I want to know how can we deform poly-surface to match multiple mesh ? Could you please help me. Thank you very much in advance.
Suraj
Hi Suraj,
If you’re looking to create a NURBS surface or polysurface over the meshes, this will require manually reverse engineering the scan. There are also some specialized plugins that may help but in general I use InterpCrv and Vertex Osnaps to draw curves through the meshes that can be used for lofts, sweeps or networksrfs.
See http://wiki.mcneel.com/rhino/reverseengineering for more info.
