Mapping in rhino 7
Hey everyone,
i have unwrapped this object and i want to have the wood texture change direction in the corner.
i dont want to explode the polysurface.
do you have any idea how can i make this happen?
Hi @dema_koutra
When you use Unwrap, make sure to select the small edge between the two strips as a seam - then you will have those two as separate islands in the UV editor, and you can rotate the vertical one to match the grain.
HTH, Jakob
Hi Jakob,
this edge appears after i do the unwrapp.
Should i explode the polysurface and then split the surface there?
Hi @dema_koutra
Ah, I see - so the front is a single NURBS surface! No need to explode the whole thing. Just use SplitFace (from inner corner to outer corner) to divide the surface into two joined surfaces - then you can select the edge as seam when unwrapping. Post the part if you having trouble getting there.
HTH, Jakob
ohhh jakob thank you so much.
great solution!!
