Hi All,
Is there a way to map curves on to the unulations of a surface?
For example, I have a countour map which i patched to make a ground surface. Now I would like all the curves from an OS map to lie on that surface.
Best,
F
Hi All,
Best,
F
Hi Felix,
Check out the Project command: that’s the job its designed to do.
HTH
Jeremy
So cool! thank you very much!
If you want to see how close your surface is to the contours then create a new set of 3D contours using the Contour command.
thats a cool tool! thanks
