finally I bought a powerful workstation with two RTX4090 gpus and I’m testing the final release of Rhino 8.
1st Is not possible to select 2 gpus for rendering. Why? I remember it was possible in the WIP releases. Blender can use multiple gpus…
2nd Using Cycles the clipping section feature doesn’t work properly excluding some objects from the cuts
3rd Clipping section clips the lights!!! Hey, why??? Some lights will disappear from the screen and you have to figure out how to bring back them on the screen again. Please avoid clipping lights from this tool.
4th Tweaking light power doesn’t work well in realtime within Cycles, it’s faulty.
I’ve found a lot of other issues and I will post new videos.
I think you must check all realtime feedback with Cycles on. Tweaking materials, objects, lighting and other stuff Cycles doesn’t update in realtime, it’s a random behaviour. I have to switch to shading then to raytrace to update Cycles.
Also rendering Cycles + wireframe isocurves doesn’t work well. Lines are horrible with low antialiasing, neither the Nvidia denoiser can fix this issue.
My Systeminfo:
Rhino 8 SR2 2023-12-12 (Rhino 8, 8.2.23346.13001, Git hash:master @ dbefe46c12cda06610a9ab683a211aa3d16f0030)
License type: Valutazione, build 2023-12-12
License details: Cloud Zoo
Expires on: 2024-03-02
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 12-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.33
> Accelerated graphics device with 8 adapter port(s)
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
> Accelerated graphics device with 0 adapter port(s)
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-6-2023
Driver Version: 31.0.15.4633
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Users\gabriele\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\IntelDenoiser\0.6.7\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 1.0.0.0
C:\Users\gabriele\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
d:\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.2.23346.13001
d:\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
d:\Rhino 8\Plug-ins\rdk.rhp “Renderer Development Kit”
d:\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
d:\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
d:\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.2.23346.13001
d:\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.2.23346.13001
d:\Rhino 8\Plug-ins\NamedSnapshots.rhp “Snapshots”
d:\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.2.23346.13001
d:\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.2.23346.13001
d:\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.2.23346.13001
d:\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.2.23346.13001
d:\Rhino 8\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
d:\Rhino 8\Plug-ins\Displacement.rhp “Displacement”
d:\Rhino 8\Plug-ins\SectionTools.rhp “SectionTools”
