I use rhino to make hard surface model bits for tabletop gaming. my items are designed in mm and smaller. The 3d printer mateiral come with tolerances on how thick parts can be this can be the main model part or the sprue I put int to connect all the pieces. The current materials need the model part to be .7mm thick and the sprue 1mm thick. Is there a tool in Rhino 8 that I can use to make sure I am within tolerances?
Shapeways for example has a wire thickness view if im with in tolerances it shows green. If Im not the part shows red and I know I need to remodel it.
