I am new to the whole 3D thing but am learning fast. I need some help however. I am trying to create a truncated cone shaped depression in a solid face. I can draw the cone shape but it is a solid whereas I need the shape as a depression. Any ideas please?
Boolean Difference is your friend! Model both the solid block and your truncated cone, then place the cone where you want the void to be. Activate _Boolean Difference, select your solid block, hit enter, then select your cone, and enter again. VoilĂ !
Make sure the polysurfaces intersect enough. Sometime, even if two of the edges are exactly co-planar, they still have issues, especially with more complicated shapes. I usually exaggerate their intersections so Rhino can perform the Boolean Operation successfully.
