I have a mesh surface of a terrain, which I have added a thickness to it in order to make it ready for 3d printing. It is an open mesh and I need it to be a closed one. I have tried the mesh repair tools but was not successful. Is there any advice?
meshbox.gh (10.9 MB)
I think the problem is with the original mesh in that its edges are not the terrain, but a more or less straight line going through the terrain. That means that the geometry on the sides does not properly join to the sides.
It’s just a guess and I think one solution would be trim a bit off the sides of the mesh first, so you don’t have that edge with the overlapping vertexes.
Thanks! Is there a way I can clean the initial mesh?
For some reason I can’t see your mesh (maybe is a NVidia Quadro driver issue). So here’s some blind notes (after finding disjoined pieces etc etc):
- Instead of thicken (may be challenging if the Mesh has issues and/or unsuitable Topology). I would suggest the approach as shown (i.e. getting the outline(s) as Polyline(s) [ more than one if inner holes are present], project in some base plane (use a Box to find the lowest pt in Z) and then “bridge” the sides via quad meshes [ on a per Polyline segment pair basis]). If you want a closed Mesh create a BrepFace out of the projected Polylines and then convent that to Mesh … then Append side(s) and bottom (with that order) to the original:
i
- There’s various ways to attempt to fix (up to a point) a Mesh with issues … but none is achievable without code.
- The Free MeshLab has various tools for that matter … but is rather complex and has lot’s of bugs.
- Have in mind that the Mesh class is using floats and not doubles meaning that for big Meshes too far from global origin … tolerance issues/failures may occur.
