Hi Eddy team,
Recently I’m trying to run simulation with buildings and trees and I found a potential issue with the make trees functionality.
In my case I have multiple buildings as well as multiple trees geometry and I assigned all trees geometry into one Eddy tree component. The issue is the top right corner of the boundingbox for all the tree geometry locate inside of one of the buildings instead of the fluid domain, which is causing a trouble for the make trees functionality, because in topoSetDict it is using the boundingbox top right edge point as the outsidePoints.
I was able to manually change the point location and replace the topoSetDict and run make trees batch file manually to get the simulation running but wonder am I correct and if yes is this something we can fix in the next version.
Thanks.
Bing
