Make surface from fillet arc
I want to know why does my closed curve cant make a surface by using Boundary Surface
here are the script
Yoga Shala.gh (26.4 KB)
Thank you!
Check the error bubble, boundary srf only creates planar surfaces. I didn’t check your definition, but i think you should try loft or sweep
I’m not sure if it’s really a neat approach , but using Patch component :
Yoga Shala(1).gh (28.3 KB)
this is good but The Path component is not optimized in algorithm speed.
Thank you!
Thank you Ali!
Thank you Cristoph!
