My problem is a bit complex.
To explain what I am doing first:
The goal is to take vertices from rhino or grasshopper geometry and use it to tell a drawing robot car where to go. I already have the code written for the robot to draw. This script will convert the vertices to the commands in the python script for the car. The python script contains the definitions goto() which makes it move to a point, and penUp()/penDown() which moves the pen up and down.
My code successfully turns the points into those commands and orders them correctly, but in order to add a polyline to the list of lines to draw I have to add input nodes to all the explode trees, entwines, and a merge and copy a cluster for it to work again.
Does anyone know of a way to incorporate the “add input node” idea into the beginning of the script to make adding polylines easier?
My grasshopper code is attached below and includes internalized rhino geometry
Thanks
Combine lists3.gh (26.0 KB)
