Hi!
As I am a Rhino lover and an interior designer at the same time,
I thought I’d make a wish list for the McNeel team in preparation
look forward to the next christmas ![]()
I gave up AutoCAD a long time ago, but there’s still some time left to give up Revit ![]()
Below is my wish list
1.FxSelectedArea or LeadreSelectedArea
The best thing that came out for me in rhino 8 was the definition hatche
through layers. It worked great for furniture, but I stumbled upon it
for the problem with the walls. Well, it is ideal to have all the walls in shape
one block and when I make sections, it’s nice to have a hatch, but…
You know how it is with interiors, sometimes we have different colors of walls, sometimes
we have different materials on the walls. And this is where a few problems arise.
It’s great that I can divide the plane into two parts without breaking the solid.
But I can calculate area + shift + ctrl for individual planes of the solid
but in the case of a description with leader + fx, either the entire back or one plane.
The ideal would be if there was a leader that counts the selected planes and you can
add and remove planes in it. Because I have to provide the square footage of the plasters in the reports,
tiles etc.
2.FxSurfaceMaterial
This brings me to the second important thing. I’m missing the fx option in leader/text in which
I could mark what material the solid has in the plane. This is important because when in drawings
I use solids for cross-sections with defined hatches, I can only use them to describe the material
layer name, which is closest to the truth, but it causes me to have to break the solids into planes
and I lose the ability to make hatches
3.FxObjectMaterial / + Inside block
Another thing that disrupts my workflow a bit is the need to make decisions between blocks
a worksession, blocks are the perfect solution for me, but! they have one drawback, which is
the advantage of worksession, I can use fx object descriptions from worksession as it would be a regular object
in the model. If I could do this relative to blocks, that would be wonderful.
4.Draging light in/out of the grout
It would be nice to be able to, like with layers, be able to drag lights into and out of a group.
If necessary, I can expand on the topics with examples, and I have already written quite a lot
Regards!
