Machine Learning python Lib in Ironpython
Hi All,
Is there away to use Sklearn, Pandas and Scipy in python for Rhino?
Not sure if these are supported in IronPython or there are other alternatives (the limitation of the .net…).
I know that raw data can be streamed out of the GH environment and used to create a learning model, but then it might be more efficient to have it directly in the GH /Rhino python environment.
Hi @fbarazi,
Here is what I’ve found on Sklearn and Pandas:
https://stackoverflow.com/questions/16171923/can-scikit-be-used-from-ironpython
https://stackoverflow.com/questions/14432059/can-we-load-pandas-dataframe-in-net-ironpython
NumPy / SciPy support in Rhino 6
So, it doesn’t look good - sorry.
– Dale
You may want to look at LunchBoxML
They are using Accord which would be accessible to IronPython
Very late reply, but big thanks Steve!
