Hi there,
I’m trying to run this simple definition, but all the components for “machine learning” are not working. I’m using the Gaussian mixture component, but it returns this error: “1. Solution exception. One or multiple errors occured!” Does anyone get the same error? LunchBox 2018.11.16 installed, but I had the same issue with the previuous version of LB.
same problem. did you figure it out?
Not yet unfortunately
i have the same problem with lunchbox
