In Windows the method to “Save As” + selecting .dwg format allowed layouts to be exported too.
In Mac the “Save As” is limited to only Rhino .3dm format. The alternative to use “Export” to .dwg has no option to also transfer layouts, only geometry.
How can I still achieve this?
Thanks
Hi Jaxx -
Hmm. In a quick test, I don’t see that here on Windows.
The alternative to the Windows SaveAs command on macOS is the ExportAll command.
SaveAs
ExportAll
But, as on Windows, I don’t see the option to also export layouts to the dwg file.
In Rhino 9, there is the new ExportLayout command that was written for this purpose. -wim
ExportLayout
Hi Wim
Thanks. If I remember correctly in Windows the layouts just get transferred into the dwg automatically with SaveAs, that’s what I meant.
Just tested: ExportAll on mac
and can happily confirm that that one does the trick!
