Lunchbox Plug-In Mac
Hi - the link that was posted here seems to work fine:
Thanks a lot! It occured to me I had to create a Food For Rhino account. So now it works! Have a great day)
Thank you… it worked
I love you Tim!
This helped! thanks!
thanks for your suggestion I managed the setup!
Hi Jeff.
I have tried everything and even opening the special components folder and nothing seems to work. The plug-in and grasshopper file does not show up on my mac. I have also tried downloading the zip file. Does anyone have any ideas or a different track? thanks in advance.
Never mind got it working! if anyone else is experiencing the same problem i found i very helpful youtube tutorial Tutorial - Grasshopper plugins on Rhino For Mac: Ladybug Honeybee, Lunchbox, Bifocals - YouTube :slight_smile:
thanks a lot really helpful
Thank you ! that is very helpful link introducing me different types to install plugin.
And I also find comment under youtube comment helps me to find good path for Rhino 7 .
In grasshopper (inside the program) go to file> Special Folders> Components Folder and drag the whole unzipped lunchbox folder there. I have Mac and Rhino 7, so yes, it works. (/Users/myuser/Library/Application Support/McNeel/Rhinoceros/7.0/Plug-ins/Grasshopper (b45a29b1-4343-4035-989e-044e8580d9cf)/Libraries)
Thank you very much for your help! It works!!! I also have Rhino 7.
Ciao Barbara,
ho lo stesso problema che hai avuto tu nell’installazione di LUNCHBOX in quanto ho un MAC: mi dà lo stesso errore e non ho il percorso nel quale inserire il plug-in.
Posso chiederti come hai fatto?
quando scarico il file. fip mi di “accesso negato” non riesco proprio a risolvere
It looks like LunchBox does not work in the WIP, only the Machine learning tab is loading.
Has anyone got it working on Mac in WIP8?
thanks a lot
Akash
Same here, only ML loads in RhinoWIP 8 on Mac. Such a shame that there hasn’t been any Mac support as it mostly ran fine till v8
Same Here !! It is very bad that it doesn’t work on Rhino 8 for Mac, since I use LunchBox almost daily…
If someone knows a fix please let us know.
Lunchbox works fine on my Intel MBP16", installed via PackageManager. It however seems to be incompatible with ARM / Apple Silicon for now. Hope the developers will update it!
Here is an interim “solution” for RH8 on AppleSilicon:
Hope this helps…
how to download lunchbox rhino 7 for mac it gives a files that says has no application to unzipp it
I have the same exact problem, did you find a solution?
installation via the package manager did not work?
