Hi!
I’m trying to close thoes two surfaces, but neither cap holes or loft using two parallel curves doesn’t work.Maybe someone have some other ideas or know what went wrong.
Looks like one of the curves isn’t closed. You can use “Closed” to check if one of them isn’t. Then you can use “Close Curve”.
I closed the curves, but the loft doesn’t show, although there is no error.
if you upload the file , you will get more help .
its not that easy to tell what went wrong without take a look to the file
loft_3101.gh (18.6 KB)
great! thank you so much!
