Loft Issue
I have a simple loft issue that I can’t figure out. There was a step in a process that @theoutside helped me out with to solve a closed polysurface. I tried to re-create solving this because I tend to learn better upon repeat. I should’ve recorded the screen because I certainly forgot a simple step in this process. I’ve attached a movie to the file so that you guys could see the issue.
Any help would be GREATLY appreciated. And thanks Kyle @theoutside for your awesome help!
Here’s the video link:
Hi Chris, it really would be much more useful to post the file with the inputs to the surface you’re making.
Pascal, will do. Here it is.
I trimmed it to focus on the issue of the tenon.
Thanks!!
I appreciate all of your help @pascal
ashissue.3dm (3.1 MB)
Hi Chris - I think I would try to structure the thing more like this:
and trim.
If I understand what you are after,
But, fwiw, I would also see if I could not greatly simplify the ‘main’ surface to avoid curvature messiness:
@Chris-Mitchell Something more like this, perhaps -
@Chris-Mitchell - this is how I’d try to lay out these surfaces.
ashissue_PG.3dm (383.0 KB)
split edge was the command we used to break up the edge and allow you to loft each part of the edge together.
you can also sweep 2 with chain edges on and use the multipart edges at the rails that are chained.
Thanks for the tip!
Kyle,
Split Edge was in fact the command! Thank you. Unfortunately, I’ve run it several times and it still leaves open edges. I can’t seem to get this to close.
@pascal - How in the heck did you find the rest of my surface? I only included the cut off portion of the upper bout in my file. What kind of magic is this?
Hi Chris - trimming surfaces only ‘hides’ the bits that get trimmed off - a trimmed face is added to the document - what you see - but the underlying surface is still there as part of the trimmed face. - Untrim gets it back. See help on ShrinkTrimmedSurface as well.
you can run sweep 2 with chain on, and use the spit edges as the rails, with the clean edges as the profile curves
fwiw- Subd may be the magic bullet for these surfaces-
guitar_demo.3dm (1.2 MB)
@theoutside . Yeah. That looks great. What does “fwiw” mean?
Also - I can’t get sweep2 to work either.
Weird. I ran untrim command and mine didn’t pop back up.
Hi Chris - Untrim works on single faces/surfaces only, so Explode or ExtractSrf your surface if it is joined in.
Perhaps
FWIW = for what it’s worth
" for what it’s worth"
matchsrf set to position may get you there
see attached file for my fix
ashissue_kdemo.3dm (756.1 KB)
+1 for doing surfaces like this with Subd tools! These are so much more difficult with traditional NURBS surfaces - you’ll get a better result faster with Subd’s, and way more fun to edit it that way too.
I will definitely look into that in the future. It appears that it’s the way to go.
@theoutside That was the trick!! I had totally forgotten to merge the edge and run the edgesrf command. Thank you SOOOOOO Much! Now I’ve got to look into SubD. You DA MAN!!!
I’m using Rhino 6. How do I access SubD commands?
