Loft curves without split lofted surface into polysurface
I loft two curves and get a polysurface, but I noted that Rhino split the surface only in one corner. Is there a possibiliy to control the loft so that I get as result one surface and not a polysurface?
Bye.
Hello - if the curves are matched - copies say, and the curve segments are tangent then you can control this in the Loft dialog:
