Hi, I would like to loft the closed curve you see below.
It consists of three curves and three lines, which I joined.
There is no error from the Loft component, but the lofted surface appears to be Null.
If your supply a single joined curve to “C” input ofLoft. then the output of Loft might be “Null”.
Loft needs at least two curves of input “C”.
If you’d like to loft using bottom & top joined curves , that would make sense. Otherwise, try to use Patch instead…
Oh right, forgot about Patch. Works like a charm, thank you!
