[EDIT] If you are using the same search terms as me, find the answer here:
http://discourse.mcneel.com/t/how-to-draw-in-a-locked-plane/14559
[SOLVED] Hey guys,
I’m looking for a similar kind of lock, but rather for a plane, instead of 1 axis.
- I’m tracing a drawing, and objects based on different heights on the Z axis,
- I am using and do want to use snapping.
- I want to the snapping to ignore the Z axis and keep in the same XY plane I started my first point at.
How can I do this? There should be an easier way to create planar polylines/curves instead of having to pull all the points to the same Z height, or to have to project every curve I make.
