Hi, i am looking for the material library settings on a Mac version 7. I would like to set a new path for a set of materials. Can’t find any options under “Tools > Options > Libraries”. I use a German version of Rhino so it reads “Werkzeuge” for Tools. Am I looking in the wrong menu/spot?
Thank you for any help.
Hi @albatros
Use the Libraries panel to navigate to the folder location you want to have faster access to and then use the “Add current folder” option in the address bar of the panel. Use the gear icon in your right sidebar’s docked inspector panels to open the Libraries panel if it isn’t already. The Render Content folder is there by default as well.
