Linked model geometry not coming in at correct location
Hi
I’ve noticed that when I get linked model geometry it is not coming in at correct location.
If I use ‘Set multiple graphic elements’ on the linked model, it returns no geometry which I believe is expected behaviour. However, if I use ‘Set multiple linked graphic elements’ geometry is returned but it looks like it is using another shared location. Is this expected behaviour?
Yes, by now we don’t handle Elements on linked models differently, so that geometry is in it’s own doument coordinates system.
You can do this to have the geometry in your Project coordinates.
Or a bit simpler
Thanks @kike that worked.
Would be great if in the future this was done automatically as the user now has to select the elements AND the linked instance.
