Link Grasshopper files to Rhino Drawing?
Is there some way to attach or link Grasshopper files to a Rhino Drawing, so that when I open the Rhino drawing and want to use Grasshopper files that were tailored specifically for that drawing, I don’t have to remember what the Grasshopper files were called or where they are. I don’t necessarily want to open Grasshopper every time I open the Rhino Document, but when I do want to open one it would be handy if they were linked to the drawing somehow.
Is there some way to do this?
If a Rhino file is necessary, I like to name it the same as the Grasshopper document and keep both in roughly the same location and vis versa. This way there’s already a visual link in terms of filenames.
Examples:
Projects
    ├  yyyymmmdd_some-project
        └ some-project.3dm
        └ some-project.gh
Projects
        └ some-project.3dm
        └ some-project_main.gh
        └ some-project_other.gh
You could potentially automate opening the appropriate files with scripting or probably even a macro, but you’d have to keep track of what files belong together, which could be rather tricky.
Hi James -
Doing it the other way around is straightforward. You can import a 3dm file in your Grasshopper definition and can “hardcode” the path and name…
Grasshopper can’t be opened without loading Rhino first though.
That’s no longer true. I’m not sure if there’s a setting to allow it, but since 7 (maybe even 6?) double clicking on a grasshopper file opens rhino grasshopper and loads the file.
Opening Grasshopper with a Marco that opens the correct grasshopper file seems to work pretty well. I made a button on a custom toolbar that does:
_-Grasshopper
Document
Open
x:\MyFile.gh
I’m curious if there is a way I can make my Rhino file automatically show a particular toolbar when I open it? I know there is a toolbar command that can show the toolbar, but is there a way to autorun a command when I open a Rhino file that is specific to that file?
I suppose so, yes. You could have “something” in your Rhino file (e.g. a document user text key pair, or a specific name for an object on a specific layer, etc…) and have a start-up script check for its presence.
Yes, but Rhino still launches first (or in tandem).
Hi, I know this is an old post, but I was looking for the same workflow and ended up building a plugin for it.
It lets Rhino and Grasshopper work with linked files without needing to manually re-import geometry every time.
I shared it here if you want to check it out:
