LineTypes Panel Name Dialog Bug
When trying to add a new LineType via the panel, the ‘name’ dialog losses focus on every character input. So to enter a name you constantly have to click again with the mouse on after every character. The other dialogs in the panel seem to work, it appears to be only the ‘name’ which has this issue. See below for example:
Environment
  • Macbook 2021, Apple M1
  • macOS 13.6.6 (Ventura)
  • Rhino Version 8 (8.8.24142.13002, 2024-05-21)
all the best,
@ed.p.may
Thanks for reporting Ed, i’m seeing this as well .I’ll update with the YouTrack # shortly.
In the meantime you can copy and paste the name change.
RH-82171
RH-82171 is fixed in Rhino 8 Service Release 8 Release Candidate
RH-82171 is fixed in Rhino 8 Service Release 8 (for those of you not running a Release Candidate).
