As you can see by the screenshot below, I have lines that I have extruded polysurfaces from. However, the lines are still visible, even though the polysurfaces are in front of them. This makes everything confusing to look at. I opened another file and everything was displaying normally. This is on a shaded view.
Thanks.
I have a feeling this is related to the tolerance. Share your model so we can take a look and definitely someone will find it out.
and run _Systeminfo in case this is an openGL issue
You might try running the command ClearDrawOrder, just in case somehow the lines got a draw in front order attached to them.
Omg thanks for this. I have been ignoring this issue for the longest time and I finally decided to go figure if it was a bug or something. Turns out, it might possibly “infect” from other files, as I usually take some elements from my older files when starting out a new project. Not a 100% confirmed thing, just kinda realised that it appears very early on in my new files recently.
