Extrusions are invisible due to curves/hatches
All the extrusions I made are somehow invisible or look really weird.
In perspective View they are all somehow “invisible” but in the other Views they are all visible and all look normal.
Does anybody know what the problem is?
Hi Alb,
Can you run SystemInfo in the rhino command line and post the results? This will give us Rhino Version, System Configuration as well as 3rd party plugin info. Thanks
Hi Japhy,
thanks for the reply, here is the SystemInfo
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Studentenlizenz, build 2023-09-24
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 12-15-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 527.83
- Windows Main Display attached to adapter port #1
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-12-2022 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-15-2022
Driver Version: 31.0.15.2783
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.34.23267.11001
SystemInfo looks OK.
Hard to tell, but this might be a ClearDrawOrder issue. If that command doesn’t clear it up can you post the file? Thanks
ClearDrawOrder worked, thank you so much
