Line types problem, help!
I’m having a hell of a time importing linetypes. I need to indicate a skylight as a dashed line, and after importing an autocad .lin file and selecting the dashed linetype, it’s still showing solid when I print. What gives? What am I doing wrong?
It might have something to do with your settings under the Print Setup > Linetypes and Line Widths settings. But without seeing the file…
File attached. I drew the hidden line and elevated it slightly above ground level as a solution, but it would be nice if the section cut would also show the ceiling lines in a hidden line, so that if we make any changes down the road to the model, the plans are updated. kitchen.3dm (1.8 MB)
