Hi, V5
select Line Tangent from Curve command from line tool set,
select circle near ‘A’ select end of line at B and instead it goes to perp on that line partway down it.
Not sure why using LMB fails, it offers RMB and pick a point and that works, but why does the LMB option go perp, just puzzled. better named Tan to perp !
Hi, I wanted tan from circle to end of line and couldnt see why the Tan from circle LMB tool couldnt achieve it, why it has a want to go perp, .
The fix is the offered rmb option but just puzzled why lmb fails. why lmb has a destination that undeclared sees a perp at destination, as one doesnt expect that to be so.
Maybe it would make more sense to describe what you’re trying to end up with using your 2 circles, and we can suggest a Command selection and use strategy.
@John_Brock
I just tested in V5 and the tangent does automatically go perpendicular to the line even if there is no persistent osnap set at all. And if End osnap is set, the ‘hidden’ Perp still overrides it. That looks like it was a bug, the only way to make it snap to the end was to use the “Point” command line option after the tangent pick. This was apparently fixed in V6.
Note that even the current WIP still has the hidden automatic perpendicular snap, but at least now any other persistent osnaps can override it. However, it is still a bit visually confusing, maybe this should be looked at.
