Is there a possibility to give an ‘offset’ to the value given by the ‘line dimension component’?
Or do you have any suggestion on how to create a bit more professional look?
I understand you point, unfortunately I am looking for an offset between ‘the arrow’ and ‘dimension text’.
As you can see in the image, the arrow-line is at the moment not visually present because the dimension text is in front.
