Is it possible to use string formatting to add an imperial value to a Grasshopper Line Dimension?
How would I have to tweak the formatting so the imperial value is calculated?
The blue Line Dim should sho the same values like the manually placed Rhino dimension with alternative units.
{0:0 mm} [{0:0}"]
If this is not possible with string formatting, I’ll use Elefront.
Can you just use Concatenate to create the text from metric and imperial inputs?
Thanks, this works:
For the sake of understanding the formatting, does anyone have a clue if and how this would be done in a single textfield just with formatting and no additional Grasshopper components?
You can include operations like division in the expression, eg:
Format("{0:0 mm}, {1:0.0 inches}", x, x/25.4)
