Lift door display bug
the style lift door disappears somehow and sometimes updates the curtain wall will show it, restart rhino sometimes help, i cannot select it using the selection tool. or change the height. If luckily it shows, after ii adjust the elevation, they will disappear again.
liftdoor4panels.val (69.3 KB)
Hi @Rebecca_Zhao did you get that sytle from this resource? Lift door 4 panels | Food4Rhino
I guess something has changed in Grasshopper from Rhino 7 to Rhino 8 so the GH definition that generates that door doesn’t work properly in Rhino 8. In Rhino 7 it works fine.
You can contact the developer of that style to report this issue.
yes, thanks
