Hello Together,
I’m currently working on a project that involves a grasshopper solution with Galapagos. I’m able to trigger Galapagos with a boolean value and also (when grasshopper is open) create a live link between the computed solutions and a web frontend. But moving to compute, things get a bit messy.
Now I wonder if Galapagos (or worse case, a custom evolutionary solver without UI) expires the solution/moves sliders, would rhino.compute directly stop computing the solution, or would it be possible to somehow keep it alive until the solver is done.
Thank you already in advance
Best Felix
