LIBIGL on Rhino8
This is a C++ to Python binding for libigl. I would like to ask if anyone could test it, specially on Windows and Mac Intel. This is a short video how to open the script folder in Python ScriptEditor and run and example file:
examples.zip (277.5 KB)
Writing bindings is fairly mechanical and simple process. You can contribute by following this package documentation:
Mesh Curvature:
Exact and heat distance for parallel offsets:
Isovalues and mesh splitting:
Parametrization:
Quad planarization:
Mesh boundaries:
Isolines:
Plane splits:
Plane split:
All worked flawlessly, the python environment took some reloading and the script editor lagged a bit, but that is nothing on your end. Screenshots are sometimes too thick, as someone forgot to turn off print preview.
Summary
Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13001, Git hash:master @ d0f731de6fe2c5fdcad78ad80faf154307815f18)
License type: Educational, build 2025-02-11
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 8-14-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.94
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2024
Driver Version: 32.0.15.6094
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
example_boundary.py
example_curvature_gaussian.py
example_curvature_principal.py
example_geodistance_multiple.py
example_geodistance.py
example_intersections.py
example_isolines.py
example_massmatrix.py
example_meshing_geodesic.py
example_meshing_plane.py
example_meshing_planes.py
example_meshing_waves.py
example_parametrisation.py
example_planarize.py
Thank you very much:)
Hello Petras
it works well here. My first use of Python and Script Editor !
Thanks for these tools
Libigl and CGAL are the 2 tools that I wanted to use.
Thank you :slight_smile:
Is there a tool in Compas to output a Mesh in Grasshopper I see that there are some file output but I don’t see a rhino Mesh. If no tool, no problem, I will make a file and read it.
Conversions from and to are described here:
Also source code for conversions of compas is here:
If you want to directly convert c++ wrapper from numpy to rhino you can use the source code too:
We just added a new method for mesh mapping using parametrization:
mapping.3dm (478.1 KB)
mapping0.py (4.1 KB)
mapping_boolean.py (4.1 KB)
mapping_tessagon_patterns.py (6.1 KB)
Patterns from Tessagon library:
Hi @Petras_Vestartas ,thank you for sharing these impressive scripts. Do you have any plans to implement these tools as Grasshopper scripts? If not, I’d be glad to do so.
You would be very welcome to implement as grasshopper scripts.
BRG tries to use Rhino Plugins or simple scripteditor python commands or vs code but there are no plans for grasshopper :slight_smile:
