GrasshopperCPythonEditor
Feature:
  • Run cpython code in Rhino.Grasshopper.
  • Debug cpython code (only for “Rhino Data” in params).
  • Auto completion when editing.
  • Pip install python lib.
  • Use Embed Python. Don’t need to configurate anything .
  • Base on PythonNet . Support to .net library interoperation .
    003
    002
    001
Release:https://github.com/chikalee/RhinoPythonNetEditor/releases/tag/v1.0
Hi @Torso,
Thank you for releasing it! Looks quite interesting!
Which cpython version does it support?
Which Rhino (6,7,8) version it supports?
python 3.8
rhino7
Hi @Torso ,
Thank you for the reply.
Any plans to compile one version for Rhino 6? :slight_smile:
No plan now .
Why my plug-in can not be published on food4rhino. I have waited for a week . Anyone helps me?
https://www.food4rhino.com/en/app/grasshoppercpythoneditor?lang=en
How do I install it from the github site? While waiting for a Food4rhino deployment…
EDIT: never mind, forgot to unblock download. :slight_smile:
I drop the component on the canvas and get this message:
Then if I try to open it, I see the editor for 1 second then Rhino crashes. Files attached.
RhinoCrashDump.3dm (210.0 KB)
RhinoCrashDump.gh (1.2 KB)
Plugin crashed on computer of food4rhino member . Dont allow to be published . You can only download from github.
I will check .
Can you offer your environment infomation?
new pre-release:Release GrasshopperCPythonEditor v1.0.1 · chikalee/RhinoPythonNetEditor · GitHub
Can you try again?
It works!
Thanks, I’ll test more next week.
Dan
Release on food4rhino:
