Bind C++ and Python
I’d like to share a technique for creating C++ and Python bindings. This approach allows you to develop your code both locally and cross-platform. The package includes a PYPI setup with GitHub Actions configured for Linux, Windows, and macOS, making it easy to install via pip in Rhino’s ScriptEditor.
It’s been successfully tested with several well-known C++ geometry libraries, including:
You can even create Python bindings for Fortran using this method! The best part is that data transfer can happen without any copies — from simple collections to unique pointers and classes.
Here’s a step-by-step guide to creating bindings for your own C++ library:
:link: Google Slides Guide
@eirannejad — Your ScriptEditor is awesome! It has made our work at ETH Zurich much easier. Thank you, and keep up the great work!
I feel privileged for being a small part of this slide :innocent:
Incredible work! Thanks for sharing!
@Petras_Vestartas
Thank you for sharing your work!
I wonder if it may be possible to use Rhino C++ from CPython that way?
Then we don’t have to take the detour via .NET.
Jess
This would be a dream!
.NET layer slows things down a lot.
Since rhino is not opensource you cannot do this.
@eirannejad
Is it technically possible to wrap any RhinoDoc method? For instance to add a single point to rhino.
We have discussed this, but are not actively working on the project.
There are already a large number of nanobind based bindings written right here:
This source currently compiles with an embedded copy of opennurbs and would need to be adjusted to a different project name and link against the Rhino C++ SDK instead. Then the effort would be to add whatever Rhino specific class bindings would be needed to make the library usable.
Do you think anyone from mcneel, in the near future, could make this working in terms of rhino integration?
I am wondering how this kind of integration works when:
a) you have open source opennurbs library
b) you have a closed source rhino software
Open or closed source doesn’t matter. We have a C++ SDK for Rhino that DLLs can use.
We can try to get this project structured for in-rhino use, but we’re all super busy right now with many other projects so it’s hard to make any promises.
For me it would be fine if it would be limited to the ScriptEditor with the SDK installed and an activated Rhino license. No compilation needed → open source only :wink:
Here is a start for such a project
Thank you very much for making it available !
Does this step exists for mac too?
Mac is still something we are trying to figure out. We are making a C++ SDK available for Mac in Rhino 9, but definitely don’t have all of the issues worked out yet.
