what you re after was called simple sweep in older rhino versions.
but simple sweep was never nicely supported - for example with error-messages etcâŚ
and there was not much feedback in this community when i tried to push this featureâŚ
even worth - it became a âhiddenâ feature.
from an old help file:
Simple sweep
Simple sweep works in cases where the shape curves intersect the rail at rail edit points. This option generates simpler surfaces in cases when the curves are perfectly set up. The surface inherits the structure of the input curves.
the most basic setup that will work looks like this:
red (one or two rails)
green (shape)
rail and shape (at start/end) need to have G0 (position) - test with _gcon command.
if you want inner shapes they must be positioned at edit Points and all shapes need the same nurbs structure.
_editPtOn (for the rail)
_pointsOn (for the shape(s))
i like _setPt best to move the shapes end points to the rails edit points.
⌠feel free to push (by answering) some of the old topics ⌠search for simplesweep and simple sweep in this forum
Why do you use the âRefit cross sections withâ option? Usually it destroys the original structure of the input curves and will try to generate a refit surface with a quite different structure.
Have you tried the âExtrude along curveâ command? ! _ExtrudeCrvAlongCrv _Pause _Solid=_No _SubCurve=_No
It preserves the original structure of the input curves, but with one caveat: the extruded ends are parallel along the path.
Note: My icon is custom made, because the default one uses a closed extruded profile, thus many people are unaware of its real power when it comes to surfacing.
An alternative is to use a trick with merging the two halves and then removing the unwanted intermediate knots:
Have you tried the thick that I described in my previous post? It works flawlessly with your curves. I also added a 3rd video above where I showed the solution with your 3dm file.
The mirroring itself does not give you a clean result. Itâs the merging and subsequent removal of the extra knot in the middle that give you a clean result which matches the input curves.
I was mainly trying to understand why the full profile behaves differently. @Lagom answer clarified it for me: when the rail goes through the middle of the profile, Sweep1 adds extra CVs, but when it touches the profile endpoint, it stays cleaner.
As I mentioned in the video description under two of my 3 videos, the Rhino developers must fix the big related to the unwanted rebuilding of the âSweep 1 railâ surface, in order to achieve a clean result similar to the âExtrude along curveâ command. This bug have been reported many years ago by multiple people, yet itâs still here in year 2026. If we are lucky, Rhino 10 may finally offer a better âSweep 1 railâ tool.
In many cases itâs not possible to use an end rail, because the latter is located in the middle, thus the user is left against the challenge to look for an unusual solution.
An alternative is to orient a copy of the profile curve to the opposite end (with the âOnCurveâ option to maintain the orientation relative to the rail curve), then build a 3d scaled copy of the rail along the end of the profile curves.
Use the following commands to achieve these two steps: ! _OrientOncrv _Pause OnCurve Copy
! _Orient _Pause Copy=Yes Scale=3D
If you build two scaled copies at either end of the profile curves, you will be able to use either ! _EdgeSrf or ! _Sweep2.
However, with that method and EdgeSrf, the surface is off of the original centre curve (left). 3D scaling and then using only one curve with Sweep1 seems the better choice (right).
Yes, this is why I showed 3 alternatives to choose from. I didnât include âLoftâ that could be built through the 3 rail curves, because it generates too much of a deviation at the top and bottom.
