How is this done? I do not see appropriate methods under the leader doc object.
See the docs for ObjectTable.AddLeader.
ā Dale
Thanks for the reply @dale,
What I meant was adjusting the position of the text but also setting the font, scale, prefix, suffix, etc.
import Rhino
import scriptcontext as sc
def EditLeader():
filter = Rhino.DocObjects.ObjectType.Annotation
rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select leader to edit", False, filter)
if not objref or rc!=Rhino.Commands.Result.Success: return rc
obj = objref.Object()
if type(obj) is not Rhino.DocObjects.LeaderObject:
return Rhino.Commands.Result.Failure
txt = ''
rc, txt = Rhino.Input.RhinoGet.GetString("New text", False, txt)
if rc!=Rhino.Commands.Result.Success: return rc
leader = obj.LeaderGeometry
leader.SetRichText(txt, leader.DimensionStyle)
sc.doc.Objects.Replace(objref, leader)
if __name__=="__main__":
EditLeader()
EditLeader.py (712 Bytes)
