Any quick way to convert a piece of Text to a leader?
via a script like this??
textobject = rs.GetObject('select text', 512)
text = rs.TextObjectText(textobject)
rs.AddLeader(rs.GetPoints(),text=text)
rs.DeleteObject(textobject)
Thanks! its a start. I’ll play with it a bit and see if i can it to the following. My coding studies have fallen off a bit.
This is in layouts so ideally it would get the origin of Text then add a second point (text origin, fixed offset) , which would allow for multiple selection as well.
my attempt in rs , which is failing at the AddLeader
Sub Main()
Dim textobjects, id, points, newpoints, text, arr1
textobjects = Rhino.GetObjects("select text", 512)
For Each id In textobjects
Rhino.Print "Object Point:" & id
points = Rhino.TextObjectPoint(id)
text = Rhino.TextObjectText(id)
newpoints = points
newpoints(0) = newpoints(0) + 1
newpoints(1) = newpoints(1) + 1
arr1 = Rhino.MakeArray(2)
arr1(1) = points
arr1(2) = newpoints
Rhino.AddLeader arr1
Next
End Sub
a python version, still not quite getting it
def ConvertTexttoLeader():
objs = rs.GetObjects("Select text",512, True, True )
if objs is None :return
for obj in objs:
txt = rs.TextObjectText(obj)
pt =rs.TextObjectPoint(obj)
pt2 = (.25,.25,0)
pt3 = [pt,pt2]
plane = rs.ViewCPlane()
rs.AddLeader(pt3,plane,txt)
rs.DeleteObject(obj)
pt3 = [pt, rs.PointAdd(pt2, pt)]
uff, that was dumb. Thanks!
