hard to help with the info you provide: post a screenshot of the pdf dialog. with all sections extended.
some guessing:
double check that you use vector int the pdf dialog.
did you change the display mode of the details ?
make a copy of the document, delete all Materials, try again.
did you try to restart your computer and rhino ? rhino is uptodate ?
try with a new empty document, set up a simple drawing and see if the pdf generation works.
Then maybe stepwise copy stuff from the old document to the new one …
Thanks for your help, I thought it would be an easy solution I was simply overlooking.
Creating a new file worked for me, but why would it not work on the other file?
Is there a reset command that will reload the print functionality?
Here is the PDF dialog of the file that doesn’t work. it matches the working dialogue box
I have figured it out, the problem was that I had an object with a semi-transparency texture in the file, and for some reason that was causing the issue. I can simply hide the object or turn off the layer it is on to export my drawings with a transparent background.
