I have two “Layout” tabs appearing on the tabs list (the one appearing whing clicking on the gear/wheel on the right). Why is it so? Does anyone else has this too? Which one should I use?
hello Pascal,
here’s what system info says:
Rhino 7 SR15 2022-2-8 (Rhino 7, 7.15.22039.13001, Git hash:master @ 2833e18992fc4b5cf99bb29c4d8e8add4f02074d)
License type: Commerciale, build 2022-02-08
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 7.9Gb)
Computer platform: LAPTOP - Plugged in [58% battery remaining]
Primary display: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 6-24-2021 (M-D-Y).
Primary OpenGL: Radeon ™ RX 550 (AMD) Memory: 2GB, Driver date: 8-26-2020 (M-D-Y). OpenGL Ver: 4.6.13596 Compatibility Profile Context 20.10.22.08 27.20.11022.8001
> Integrated accelerated graphics device with 3 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 8-26-2020
Driver Version: 27.20.11022.8001
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Geometry Gym\Rhino3d\ggRhinoIFC.rhp “ggRhinoIFC” 1.7.11.0
C:\Program Files\Geometry Gym\Rhino3d\BullAnt.rhp “bullant” 1.4.4.0
C:\Users\Tim\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\ColorPicker (336da4ab-03d3-42ca-b1fb-313bfd4c1157)\2019.2.15.811\ColorPicker.rhp “ColorPicker”
C:\Users\Tim\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\RealDrawings (9aaa3b93-9ea4-4425-b44e-8a8c4500c274)\1.0.7038.31206\RealDrawings.rhp “RealDrawings” 1.0.7038.31206
C:\Users\Tim\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
thanks wim,
I was able to disable it through “options>plug-ins” but I couldn’t uninstall it through the package manager. Did I miss something?
I tried to remove the files at “AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\RealDrawings (9aaa3b93-9ea4-4425-b44e-8a8c4500c274)” but it still appears in “options>plug-ins”, and on the side panel.
If you deleted the files, then that plug-in is no longer on your system. There is related data stored in the registry that the plug-in manager is looking at to display the plug-in information which is why you are seeing this still in the plug-in manager.
