Layout Size Restriction
This morning I wanted a layout to be 16.5" x 10.125", but then noticed that layouts can only be sized in increments of tenths of an inch (10.125" becomes 10.1", etc). Why is there a restriction on this?
Are you sure?
It could just be the display precision you have set currently.
Look in Settings > Units. If you want to see 3-digit precision displayed, make sure that’s how it’s set.
I suspect your display precision is set to 1 digit.
Thanks John, I just checked, but those settings don’t appear to be affecting what I’m able to see/enter for layout size.
Adjusted layout unit settings:
What I see in the layout properties dialog:
Hi Brayton -
I’ve put your request on the list as RH-87871 Layout: Size Precision Request
For the time being, you could switch to millimeter in that dialog box. That’ll give you increments of 0.00393… inches.
RH-87871 is fixed in Rhino 8 Service Release 22 Release Candidate
Thank you!
