Rhino is in a state where the WHAT command is disconnected from the file settings such that it displays measurements in feet-inches, regardless of what I put in the project settings.
Restarting Rhino and Rebooting did not fix the problem.
Properties>Details displays according to the project settings and gives a different result than WHAT does.
So they both appear disconnected from the settings. Could this be something in the RHINO configuration that has gotten screwed up? Apparently, I am the only one seeing this.
Hello - you’re not the only one seeing it - I can confirm they do not match, I’ll get it on the bug pile, thanks.
Well, not quite - the resolution in What does seem to correspond, so far, to file settings.
Hello- that does not happen here - shot in the dark… do you by chance have testNumberFormat set to ‘accurate’? I think not, you’d gen even more zeros, but just in case.
