Hei, is there any way how to edit texts in layouts from grasshopper directly ? actually i create title block manually and i aligned it to template layout. Thanks for help!
Thanks!
Anything is posible, but i would suggest you make a bakground grid and set the print width to ‘no print’, it will be in most cases easier and faster to move things manually - group the sets of lines + text you want to move and you can practically just snap around the layout
thanks,
arkadius
