Recently I ran into issues when printing details on a layout.
Problem is that for the details, their gray background is printed despite a correct preview (white) and correct printing previously:
I cannot seem to find a cause; anyone else seeing this or suggestions for a possible solution?
At some point it looks like you checked the “Background color” option in the Visibility Panel in the Print command interface.
Go in and clear the check mark.
Hi Steve,
Found it; it was the AutoCplane plugin
I tried installing the latest version and now the viewport labes are printed.
I’ll hail @Pascal: Pascal no worries for me I’ll just disable the plugin before printing layouts.
I’m having a similar issue in rhino 8.
I unchecked print background, restarted rhino several times. tried a different .pdf printer.
Turned off Auto CPlane. No luck. Anyone got any tips?
