Hey!
Newbie question: is there any command like UnrollSrf but that objects will not unoll completely but rather flat to a plane for 3D CNC fab … ie retain their polygon properties … this is driving me insane :
Hey!
Hi Sammy,
I’m not sure I completely understand your question, but if you want to “unroll” a mesh (polygons) you can try the Squish command.
Beware, Squish is a WIP so to speak and doesn’t use the same algorithms to unroll as UnrollSrf.
cheers,
Hi Sammy,
Maybe I understand your question incorrectly, but if you want your modeled geometry to retain its volume and you want to reorient each one individually to the world construction plane, Orient3Pt is a very nice command and will allow you to do this with a great deal of control. This command has to be run for each object separately.
-S
It works !! Brilliant thanks !
