I made a model and did the “Made2D” command but was unable to change the layers from the command. I tried to change the color and it wouldn’t change but I am able to change it to dashed lines. When i go to print the color does not show up.
Hi Alexandra - what do you mean exactly? Is this what you are trying to change, the parent layer name?
Hello! I am trying to change the line color to gray but it stays at black.
Hi Alexandra - Does the layer indicate a color change in the layer dialog? Note that print color is not necessarily the same as display color -
in the Print dialog you get to choose.
It should be as light as the trees
